After starting the server it just stops and hangs and is unavailable through architect, contributor, etc.
Attempted rebooting the entire server and just the TM1 Service.
The last 4 lines of the Server log are as follows:
1904 INFO 2010-11-09 19:12:31.013 TM1.Server TM1CubeImpl::ProcessFeeders: Computing feeders for base cube 'Plant Forecast'.
1904 INFO 2010-11-09 19:12:31.013 TM1.Server TM1CubeImpl::ProcessFeeders: Done computing feeders for base cube 'Plant Forecast'.
1904 INFO 2010-11-09 19:12:31.013 TM1.Cube Done loading cube Plant Forecast
1904 INFO 2010-11-09 19:12:31.013 TM1.Cube.Dependency Adding cube dependency: cube "Plant Forecast" depends on cube "Product Information"
This is where it has stopped 3 times now.
Is this issue being caused by a feeders problem?
I am not very familiar with cube dependency, any help with this would be greatly appreciated.
thanks.
TM1 Server stops loading
mastertito4
- Version: 9.5+
- Excel Version: 2007 and 2003
mastertito4
- Version: 9.5+
Re: TM1 Server stops loading
We Commented out feeders in one of our cubes and that seemed to be the issue
