hello'
i have a question:
How Run process in TM1 web.
because in folder application i don't see process
thanks
comma
- Version: 9.5.0 64-bit
- Excel Version: 2003 SP3
Re: How Run process in TM1 web
It can be found under Administration, not under Applications.
And then on the right column, choose the Process you to run, and click Execute Process (like a play button)
- TM1Web Processes.PNG (6.79 KiB) Viewed 5464 times
Windows Server 2003 Enterprise x64
Windows XP Pro 2002 SP3
Internet Explorer 7
Internet Explorer 7
comma
After I read again your question, maybe what you mean is that you cannot see a process under the Applications folder after you have added the process to the Applications folder. If this really is what you mean, then I experience the same problem too after I tested it.borisslu wrote:because in folder application i don't see process
I tried to create a new folder, and then added one process to this folder. When I checked it on TM1 Web, the new folder was not visible.
Then I added a URL to this folder, and this folder become visible with just a URL listed under it and no process.
So I'm guessing that Applications folder cannot list process when opened using TM1 Web. The Developers Guide only says:
The guide does not mention anything about publishing Process in Applications folder to TM1 Web.All references to cubes, views, files, and URLs in TM1 applications are automatically available in
TM1 Web.
Internet Explorer 7
Internet Explorer 7
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
You can also run a process with Action button from a websheet.
A websheet can be inserted into any Application folder.
HTH
HTH
Best Regards,
Peter
Peter
hi
i see a process under the Applications folder
how i add Action button ? to websheet and
add a websheet into Application folder.
thanks
thanks
