I have developed a spreadsheet using VB and published in Applications and trying to open in TM1 web but by default its opening in TM1web browser so am not able to see my VB creation., I want to assign this single spreadsheet in TM1 web to open using Excel .... How can i set it???
One restriction is i want to set only this VB used spread sheet to open in excel all other spreadsheet must open in TM1 web itself..
Thank you for your time..
Open spreadsheets of TM1 web in Excel
- vinnusea
- Version: 10.2
Vinnusea
Vinnusea
Re: Open spreadsheets of TM1 web in Excel
There is no way to do what you are asking. The TM1Web interface and Perspectives (Excel) are two separate client environments. If you click on an Application through TM1Web then the application will open in TM1Web. If you click on it through Perspectives it will open in Perspectives (if a view) or Excel if a spreadsheet.
