is there a simple way to clear all values of a dimension entry (without deleting and recreating the dimension entry)?
The purpose is that I get billing data fpr two dimension entry of a cube. Because the delivered data are the complete snapshot of the previous day and values may be exists anymore I wanted to clear all values before importing the data.
I have no way found to simple clear all the values. I tried to remove and recreate the dimension entry, but this will doesn't work well (the dimension entry will be permanently removed from subset).
Does anyone have an idea?
Many thanks in advance
Steve B.
How to clear all values
- jim wood
- Version: PA 2.0.7
Re: How to clear all values
Hi Steve,
Check out the following thread: http://forums.olapforums.com/viewtopic.php?f=3&t=3027
Jim.
Jim.
- rkaif
- Version: 9.1 or later
In a TI Process you can use CubeClearData() function which will clear all the values in a cube.
Alternatively, you can also clear a specific portion of a cube using ViewZeroOut() in the Prolog tab of TI Process.
Cheers!
Rizwan Kaif
Rizwan Kaif
- Steve Vincent
- Version: 10.2.2 FP1
Do what now? What version did that appear in? 9.0 makes no mention of it in the help files...rkaif wrote:In a TI Process you can use CubeClearData() function which will clear all the values in a cube...
comma
- Version: 9.5.0 64-bit
- Excel Version: 2003 SP3
From 9.5.0 Reference Guide:Steve Vincent wrote:Do what now? What version did that appear in? 9.0 makes no mention of it in the help files...
I don't know whether this function exists in version prior to 9.5.0 or not.CubeClearData
This is a TM1 TurboIntegrator function, valid only in TurboIntegrator processes.
This clears all of the data in a cube.
This function is much faster than doing an operation such as creating a view to cover the entire
cube, and then doing a ViewZeroOut() to zero out the entire cube.
Note: This call just deletes the cube data, it does not delete and re-create the cube itself. This has
implications when sandboxes are used. If a cube is deleted and then re-created any sandboxes a
user may have will be discarded, since the cube against which those sandboxes were created was
deleted (even though a cube may have been re-created with the same name). If however the Cube-
ClearData() call is used, the sandbox data will still be considered valid, since the cube against which
the sandbox was created continues to exist.
Windows Server 2003 Enterprise x64
Windows XP Pro 2002 SP3
Internet Explorer 7
Internet Explorer 7
It does not. It is a great idea and I will definitely use it whenever I build my first model in 9.5.1.comma wrote:I don't know whether this function exists in version prior to 9.5.0 or not.
- Steve Vincent
I've not looked at 9.5 for a while so thanks for that, interesting to know. I can't think of any of our models where an entire cube is cleared, but handy in a development context certainly.
Interesting to know. I can use it in some models.
In fact, it replaces the statements:
But if it is a faster method, that would be a more important reason to start using it.
Thanks.
Wim
ViewCreate('CubeName','MyTempView');
ViewZeroOut('CubeName','MyTempView');
ViewDestroy('CubeName','MyTempView');Thanks.
Wim
