I want to insert a hyperlink in an excel-sheet that references another excel-sheet in the same file with a specific cell. I did it as described in the web tips and techniques pdf from cognos. When I publish it and open it in tm1web and click on the hyperlink the cursor is on the defined cell but the first view of the sheet is not to the point where the cursor is.
Have you had the same issue? Is there any solution for it?
Thanks a lot,
Toto
