TM1/Rules
Santiago
Version: TM1 9.5
Excel Version: Excel 2003
TM1/Rules
Post by Santiago »
Hi all
I have a doubt. As I can do to make the left side of the cube rule can refer only to children of certain parent (consolidated) in one dimension. Also, as a reference on the left side of the rule to consecutive elements without having to list them all.
Thank you very much to all
Best regards
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: TM1/Rules
Post by rkaif »
Santiago wrote:Hi all
I have a doubt
To clear your doubts you need to read the Manual. Here is a link for you:
http://publib.boulder.ibm.com/infocente ... gTM1_.html
Cheers!
Rizwan Kaif
RTFM
Version: 9.5
Re: TM1/Rules
Post by RTFM »
I have a doubt
@Rizwan,
Did you actually try to understand the question?
@Santiago,
I'm not sure whether I understand your question - if you're wondering whether you can refer to a list of elements in the area definition of the rule by using a consolidated element, than the answer is no. But you can use f.i. the ElIsAnc fuction in the formula part of the rule to make the rule apply only to N level elements underneath a certain node.
Re: TM1/Rules
RTFM wrote:
I have a doubt
@Rizwan,
And it's you who says this? With a username like that... ;-)
Santiago,
Use the elisanc, eliscomp, elispar functions. Or you attributes to decide what elements are affected.
Functions go on the right hand side of a rule, NEVER on the left hand side.
Wim
