Quickly Determining Your Current TM1 Version
Posted: Wed Oct 20, 2010 5:10 am
by Alan Kirk
This is a tip from someone at IBM who I'd like to give credit to, but he may wish to remain anonymous so I'll leave it at that for now. I'd forgotten about it until I was going through my past e-mails recently. Note that this only works with more recent releases of TM1; in version 9.0, for example, the files are not tagged with this information.
If you need to quickly determine which version of TM1 you're running for support purposes (the versions of all files), especially if you've applied hot fixes, you can do the following:
(a) Open Windows Explorer to the Bin folder of your installation.
(b) Put it into List view.
(c) Right click near the top of the list (in the heading tiles) to bring up the field chooser as shown:
Go to the More... option and scroll down until you find File Version and Product Version, then check those boxes. Note: File Version will only be found in XP / Server 2003 operating systems or later. You won't find it if you're still running Server 2000.
You should now be able to easily see the version numbers of all relevant files:
Re: Quickly Determining Your Current TM1 Version
Posted: Mon Jan 31, 2011 7:43 pm
by Kim
If conditions are as Alan mentioned, you can also find the version by simply right-clicking on the the .dll/.exe file of interest, choose Properties > Version > then select Product version. This may be easier, especially if you don't want to have the extra columns showing in your Explorer view.
Posted: Mon Jan 31, 2011 8:17 pm
by Alan Kirk
Kim wrote:If conditions are as Alan mentioned, you can also find the version by simply right-clicking on the the .dll/.exe file of interest, choose Properties > Version > then select Product version. This may be easier, especially if you don't want to have the extra columns showing in your Explorer view.
If you're looking for one file, possibly. I believe that the suggester's intent was to enable an overview of the versions of all files to be visible (particularly when looking for incompatibilities), so that you don't have to have the IBM support person sitting on the line as you check and read each one out manually.
