I have searched through the forums and was able to find any help regarding a possible process that would delete duplicate elements within the same roll-up/hierarchy.
I have a products dimensions with 9 different roll-ups, and one (and most likely many others) of my elements actually appears 11 times. I have confirmed that it is showing up in the same roll-up twice, same element with the same attributes, data, etc. Since I am dealing with around 5000 unique elements in this dimension I was hoping there would possibly be a process that can be written to delete the extra elements?
Example of the error:
Σ-Material Type
Σ-Market Segment
_____Σ-MKT_A
________n-PARTNUMBER_12345
________n-PARTNUMNER_12346
_______n-PARTNUMBER_12347
_____Σ-MKT_B
________n-PARTNUMBER_12340
Σ-End Customer Group
So Market Segment is one of multiple roll-ups, but with in one single roll-up (market segments) the same element is appearing twice.
I was hoping to write a process that would do something similar to the following:
IF element exists more than once in a given roll-up,
Delete all those elements, then, Create that element once.
Else,
STET
Any thoughts? I am relatively new to TM1, I have been working on it all day every day for a month and a half now.
THANKS!
TM1 Duplicate Element Delete Process
mastertito4
- Version: 9.5+
- Excel Version: 2007 and 2003
Re: TM1 Duplicate Element Delete Process
Is it appearing more than once in the actual dimension or just more than once when you are looking through the subset editor? There is a huge difference.
mastertito4
- Version: 9.5+
Both.
it shows up 11 times in the actual dimension, when there is only different 9 roll-ups.
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
It is probably a slowly changing dimension hierarchy therefore you need to destroy the hierarchy in the prolog session everytime before rebuilding it.
dimension='aaa';
num_of_elements=DIMSIZ(dimension);
index1=1;
while(index1<=num_of_elements);
element=DIMNM(dimension, index1);
num_of_parents=ELPARN(dimension,element);
index2=1;
while(index2<=num_of_parents);
parent=elpar(dimension,element,1);
DimensionElementComponentDelete(dimension,parent,element);
index2=index2+1;
end;
index1=index1+1;
end;
dimension='aaa';
index1=1;
index2=1;
index2=index2+1;
end;
index1=index1+1;
end;
Best Regards,
Peter
Peter
mastertito4
- Version: 9.5+
I will give that a shot.
Thank you very much Peter!
mastertito4
- Version: 9.5+
Found the problem,
in the data source we were seeing elements named something like
PARTNUMBER 111 234 456X
and
PARTNUMBER111234456X,
TM1 was loading both of these into the same roll-up and making both of them in the first format
"PARTNUMBER 111 234 456X"
Not quite sure why it got rid of the spaces in the second one, but it did.
and
Paul Segal
- Version: TM1 11 and up
As we know, Jim, TM1 always disregards spaces in element names. PARTNUMBER 1111 is the same element as PARTNUMBER1111 as fas as TM1 is concerned.mastertito4 wrote:Not quite sure why it got rid of the spaces in the second one, but it did.
Best
Paul
