I could not save a rule due to ambiguous. It has some dimensions (for example, year and staff code, location, etc.), and year and staff code have same element. When I tried to save a rule on Rules Editor with year, TM1 warned as ambiguous of both of SKIPCHECK and FEEDERS - element of year and staff code is 2010.
So, could you kindly tell me how to set a rule with specific dimension.
Thanks and Best Regards,
Yukiya
Ambiguous error
- rkaif
- Version: 9.1 or later
Re: Ambiguous error
In your rules, you need to mention the element name as per this syntax:
So it would be [Year:'2010'] or [Staff_Code:'2010'] in your case.
Dimension_Name:Element_Name
Cheers!
Rizwan Kaif
Rizwan Kaif
- Version: 102
Re: Ambiguous error
Dear Rizwan,
Thank you for your great advice.
I could setup a rule.
Yukiya
Yukiya
- Version: 9.5.2 FP3
Re: Ambiguous error
One more thing, if your dimension has a space in its name (TM1 allows it, but some of us have best practice not to put them there) you must also put it into apostrophes:
['Dimension with spaces':'Element with or without_them_it_just_does_not_matter'].
