TM1 Web Customize Skins
Posted: Tue Oct 05, 2010 11:33 pm
by bjenkins
Is there a trick to chance the skins for TM1 Web? I followed the instructions on IBM and changed the web config file but nothing seems to change when I open TM1 Web. Any tips would be appreciated.
Thanks.
Re: TM1 Web Customize Skins
Posted: Thu Oct 07, 2010 1:58 am
by laenen
Do you want to post a screen shot? Are any areas changing? IBM has a policy that the header is not allowed to be changed
Posted: Thu Oct 07, 2010 2:14 am
by Alan Kirk
laenen wrote:Do you want to post a screen shot? Are any areas changing? IBM has a policy that the header is not allowed to be changed
Out of curiosity, what's the definition of "the header"? I haven't used Web for a while but I recall that most parts of the display could be changed, including the links at the top such as the "Analyze" one to EV. It was easier when there was a readily available Customizer tool, but some under the hood work could change what Customizer couldn't. Of course I haven't used Web with 9.5 yet.
(And why do I feel a sudden compulsion to fire up Web again and create a hack which makes exactly that change...
Posted: Thu Oct 07, 2010 1:30 pm
by laenen
APAR PM20242
Skin Support not working in TM1Web 951
Changing the web.config "CustomStyle" parameter to activate a new custom style sheet (.css) is not working under 9.5.1 (as documented in the TM1Web PDF, Ch 7).
Note: both new custom skins, and the predefined skins that ship with TM1Web do not work.
