Note the file must be in the same directory as the cfg file and that you must have at least version 9.4.lotsaram wrote:By default TM1 logs everything in GMT.
It is a little known fact that this doesn't have to be the case. Just edit the tm1s-log.properties file in notepad and change the time stamp property from "GMT" to "Local" and restart the server and TM1 will then log in local server time. (However only do this if you are not replicating servers across time zones!)
Changing the log time to local time
- Martin Ryan
As pointed out by lotsaram in this post: http://forums.olapforums.com/viewtopic. ... 32&p=15535
