creating a formula based on current member
stingo
Version: 9.1 onwards
Excel Version: client dependant
Post by stingo »
I'm translating a system from SAP BPC to TM1, I have to create a formula like:
[VL_0000000_D]= if currentmember = DB('APS_PnL',!APS_Entity,'VL_0000000',!APS_RPTCurrency,!APS_DataSrc,!APS_Scenario,!APS_Time,!APS_Account_PnL),
DB('APS_PnL',!APS_Entity,!APS_Product_PnL,!APS_RPTCurrency,!APS_DataSrc,!APS_Scenario,!APS_Time,'VL_0000000'),
DB('APS_PnL',!APS_Entity,!APS_Product_PnL,!APS_RPTCurrency,!APS_DataSrc,!APS_Scenario,!APS_Time,ELPAR(PnL,'VL_0000000',1)
the fact is I honestly don't know how to specify the current member condition.
is there a way to specify it?
Thanks in advance.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: creating a formula based on current member
Post by Michel Zijlema »
I'm not sure what you're expecting here, but if you're specifying a rule for the element ['VL_0000000_D'] (don't forget the single quotes), the rule will only be calcultated when the element 'VL_0000000_D' is included in the selected area... So if element 'VL_0000000' is in the same dimension as 'VL_0000000_D', the condition in the rule is useless, because the rule will never fire for element 'VL_0000000'.
In general, you can use !dimname @= 'SomeElement' to check whether the current member in a dimension 'dimname' matches the element 'SomeElement'.
Michel
