Unable to Load TM1 Workflow from Perspectives
Posted: Mon Sep 27, 2010 7:11 am
by Radhika
Hello everybody,
Recently we had installed TM1 Workflow v9.4.1 on a Windows 2003 32-bit machine. But when I try to access TM1 Work flow from TM1 Perspective v9.4.1 (intalled on the same machine),
When I go to TM1 Perspective --> TM1 -->TM1 Workflow --> ADMIN ---> I get the error message
Microsoft Visula Basic: Compile error in hidden module : frm Task Actions .
Anybody, please help me.
Radhika
Re: Unable to Load TM1 Workflow from Perspectives
Posted: Mon Sep 27, 2010 9:07 am
by Pim van Putten
Dear Radhika,
We have had the exact same error mesage in TM1 9.4.1 and this is what the IBM engineers came with:
This is a known problem with a microsoft fix(KB960715).
To resolve this problem,
Could you please check the folowing registry keys are DWORD value 0 on the client:
(If you are unsure about editing the registry, please get your IT dpt to do this.)
2C247F23-8591-11D1-B16A-00C0F0283628
BDD1F04B-858B-11D1-B16A-00C0F0283628
C74190B6-8589-11D1-B16A-00C0F0283628
0ECD9B64-23AA-11D0-B351-00A0C9055D8E
Also please check and see if the last key is listed twice. If it is, delete the key and reinstall
workflow.
I hope this helps, it worked for our client at the time.
Gr. Pim
Posted: Tue Sep 28, 2010 9:09 am
by Radhika
Hello Pim,
Yes you are right, I have the below registry key for which the DWord value is 400.
0ECD9B64-23AA-11D0-B351-00A0C9055D8E, I changed the value of DWord from 400 to 0..then it worked.
Thank you for your solution.
Radhika
