Need instructions to use TM1 on Citrix
highlnder8
Version: 9.4.1
Excel Version: Excel 2007
Post by highlnder8 »
After a year of working on my IT department to allow people to use Citrix to run TM1 from our remote sites, they have finally said ok. However, they want some documentation on how to configure TM1 for use on Citrix. So, i go out to the IBM site, find a document from Jan 2009 that is exactly what I need!! Yay!
Wait for it...
I give it to my IT guy and he says - um, this version of Citrix in these instructions is nearly a decade old. Do they have any instructions with a current version of Citrix? If not we can't do this.
Now I can't reach anyone at IBM that has something new...so I turn to you all for help in this area. Does anyone have a set of instructions to install TM1 on a current version of Citrix and configure it properly?
Thanks in advance for your assistance. :)
Re: Need instructions to use TM1 on Citrix
I don't have any document explaining how to use the TM1 cleint on Citrix nor have I ever seen one. It is my understanding that using TM1 on Citrix is not an "oficially supported" implementation. That being said, I have helped several clients install it and it's nothing special. All you have to do is install it on a regular PC with a registry tracker on and record the changes it makes and then duplicate that on your Citrix client image. I'm pretty sure that's exactly the same thing you do for any other app you want to put on a Citrix image.
highlnder8
Version: 9.4.1
Thanks Tomok!
