Hello!
Tell me what ports should be opened on the client side to work with TM1 server.
I found tm1_install 4 types of ports:
5495 TM1 Admin Host port number
5498 TM1 SSL Admin server port number
12346 TM1 Client Message port number
12345 TM1 server port
Thank you
Q about ports access TM1 (+)
avvoronkov
- Version: 9.5.1
laenen
- Version: 9.5
- Excel Version: 2003
Re: Q about ports access TM1 (+)
Note that the client message port is dynamically generated therefore the default is 12456 but it may try to bind to 12457 unless you define the port in your config file
