Question regarding a DB function in my rule
ChrisF79
OLAP Product: IBM TM1
Version: 9.5.1
Excel Version: 2007 SP2
Post by ChrisF79 »
I've inherited a rule that says,
IF ( (ELLEV('QAD Sites - Locations',!QAD Sites - Locations) >0) & (!QAD Entities @= '5000'),
DB('QAD Inventory',!QAD Entities,!QADInventoryCostSets,!QADInventoryBuyers,!QADInventoryStatus,!QADInventoryType,!ItemNumbers,!InventoryMethods,!QADProductLines,'5000 - P001 - 1',!QADSuppliers,!Team,!QADInventoryMeasures),STET)
What exactly is this doing? I don't understand what the ! is in the IF statement or the DB.
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: Question regarding a DB function in my rule
Post by rkaif »
DB() is a Rule function in TM1 which is used to return a value from a cube.
! (exclamation sign) can be used before the dimension name to get all the element names within that dimension.
For example if your Time dimension has elements 2008, 2009 and 2010 then within your rule you can say !Time which will make the rule applicable to all the elements in the time dimension.
Hope that helps,
Rizwan Kaif
Cheers!
Rizwan Kaif
ChrisF79 wrote:I've inherited a rule that says,
From the TM1 Rules Guide:
The name of the appropriate dimension preceded by an exclamation mark (!). This is called variable notation, which indicates that the reference applies to the element in the external cube that corresponds to the value currently being requested. For example, if a DB function is used in a formula that calculates a value for Belgium, the argument !Region resolves to Belgium.
Suharsh
Version: 9.5.2
Post by Suharsh »
@Alan,
Thanks for the information below. But I have a question. We are saying that an "!Year" refers to all the elements in the year dimension.
Then How does TM1 parse the cube cells which has rules applied to them. I mean to say, just as Turbo integrator parses the data row by row. How does TM1 parse the cells which has rules on them?
Also Using an Exclamation sign allows referencing a consolidated element in that dimension as well?
Suharsh....
asutcliffe
Version: 9.4.1 - 10.1
Excel Version: 2003 and 2007
Post by asutcliffe »
Alan Kirk wrote: From the TM1 Rules Guide:
I don't think I can improve on Alan's answer really.
However I like to think of it as the "!" notation returning the name of the element of the named dimension that the rule is being applied to.
By the way, this is kinda the same question you asked over here - http://www.tm1forum.com/viewtopic.php?f=3&t=6834 - so someone is probably going to suggest you read the "requests for assistance guidelines" soon - http://www.tm1forum.com/viewtopic.php?f=3&t=1037
Suharsh
Version: 9.5.2
Post by Suharsh »
Thanks for the reply. Yes, I did post a similar question there, as I later realized that this is a better thread to get this question answered.
Suharsh....
Sukhen Sharma wrote:We are saying that an "!Year" refers to all the elements in the year dimension.
In this case the !Year actually means all the elements in the Year dimension that are included in the area of the cube indicated in the left hand side of the rule statement.
