TI IsNull Function
- Eric
- Version: 9.4
- Excel Version: 2003
TI IsNull Function
Anyone know the syntax for the TI IsNull function?
Eric
Eric
- Martin Ryan
Re: TI IsNull Function
Didn't know there was one, though if there is, the syntax should be in the help files - though I find the Cognos ones aren't quite as easy to search with as the old ones. (Again no TM1 on this computer, so can't tell you specifically).
Failing that, what are you trying to achieve?
- Eric
- Version: 9.4
Wish it was that easy. It is mentioned in the Guide, but not in the help and there is no syntax. I looked for over an hour! How frustrating.
Eric
Eric
- Eric
- Version: 9.4
Sent a ticket in. We will see.
Eric
Eric
- John Hobson
- OLAP Product: Any
- Version: 1.0
- Excel Version: 2020
Eric
In my help file 9.1. Sp3 it gets one mention as a "reserved word" but nothing else.
J
J
John Hobson
The Planning Factory
- Eric
- Version: 9.4
Here is the syntax. I have not given it a try yet, but I think it might only be valid in the Data and Metadata tabs,
if (ISNULL(myvar) = 1)
#its null
else
#its not
endifRegards,
Eric
Eric
- Renaud MARTIAL
this function is perhaps used when you retrieve data from an ODBC data source ?
Its syntax looks like the one used in plain SQL to check null values ...
Renaud.
Renaud.
- Eric
- Version: 9.4
Ding! Ding! Ding! You are correct, great Insight (pun.....maybethis function is perhaps used when you retrieve data from an ODBC data source ?
Eric
Eric
