Zero Out of Cube with String value as picklist
Posted: Sat Aug 28, 2010 3:38 pm
I'd just like to check with you guys, when you zero out a cube with a mix of string & numeric elements and the string containing a picklist. Shouldn't the picklist be cleared of any content during zero out? I just want to check is this is normal or not in TM1 since for none picklist string elements it does clear the contents of the field.
