I have created a TM1 Contributor application but when I click on deploy, I get an error " An Error Generated By a TI Function".
I don't even know how to debug this problem or which log files to look into. Can someone please help on this?
Thanks...
Deploy Application Error TM1 Contributor 9.5.1
tryinghard
- Version: 9.5.1
ajain86
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
Re: Deploy Application Error TM1 Contributor 9.5.1
the deployment of an application is done using control TI processes. In your logs folder, you might have a log file from 1 of these processes that might give you more detail into the issue.
Ankur Jain
tryinghard
- Version: 9.5.1
ajain - thanks for the reply. I was able to resolve this problem through the log files; however, I have a different problem now
After deplyoing when I open a node for the first time it opens fine, but when I open another node I get an error message
"Object Reference not set to an instance of an object". I am not using SUBNM in my entire model.
Do you have a clue what is happening?
ajain86
Are you opening the second node without closing the window for the first node?
I have never encountered the error.
Ankur Jain
