Hi TM1 gurus,
I have a cube with one of the dimension with one element which is a date(May 31, 2010). This will be update constantly every month i.e it will change to June 31, 2010. I have created an excel application by slicing the cube and uploading it to application folder. How can i make the excel application constantly updated when ever the month changes.
Daya
Auto Creation of Websheet
Re: Auto Creation of Websheet
Using a calendar might be a good start, given that June has only 30 days...daya007 wrote: I have a cube with one of the dimension with one element which is a date(May 31, 2010). This will be update constantly every month i.e it will change to June 31, 2010. I have created an excel application by slicing the cube and uploading it to application folder. How can i make the excel application constantly updated when ever the month changes.
Aside from that two possible ways are:
(a) Have a public subset defined as something like "Current Month", and have an automatically scheduled TI update that subset each week / month / however often you need. You can then use a SubNm formula pointing to that subset. We use that approach for a number of our subsets which are time-related. Or
(b) Have a Dates lookup cube which will allow the worksheet to look up the month corresponding to the current date. You can use standard Excel date / text formulas to drive a DBR formula in the worksheet.
daya007
- Version: 9.5.1
- Excel Version: 2003
thank you Alan.
