Using SubsetCreatebyMDX in a TI
dan.kelleher
Version: 9.4
Excel Version: 11
Post by dan.kelleher »
I'm having trouble creating a dynamic subset in MDX, getting an error:
"Account Director",Data Source line (1) Error: MetaData procedure line (10): Could not create dynamic subset:
Here is my TI Process code:
strMDX1 = '{FILTER( { HIERARCHIZE( {TM1SUBSETALL( [Resource] )} ) }, [Resource].[' | strRole;
strMDX2 = '] = "1" )}';
TextOutput('C:\Temp\Debug_Metadata.txt', strMDX1 |  strMDX2);
SubsetCreatebyMDX(strRole | '_subset', strMDX1 | strMDX2);
This is what my debug text file produces:
"{FILTER( { HIERARCHIZE( {TM1SUBSETALL( [Resource] )} ) }, [Resource].[AccountDirector] = "1" )}"
Which works fine when I paste it into my MDx expression window in the Resource subset editor.
Any ideas would be much appreciated. Could this have anything to do with the fact that it's a blank subset once it's created?
Dan
Re: Using SubsetCreatebyMDX in a TI
Does the subset already exist? If yes, try to insert a SubsetDestroy command.
dan.kelleher
Version: 9.4
Excel Version: 11
Yes, I was running that in another process.
For some reason it didn't like creating an empty dynamic subset so I've forced it to have at least 1 element. Works fine now.
Thanks for the suggestion.
Dan
