Rule for Leaf of an item
- Version: 9.5.1
I am trying to apply a rule only to the Leaf of a particlaur item in the hierarchy. The cube has 6 dimensions and one dimension has 6 levels.
Eg.if this is the hierarchy I would like to apply the formula to Leaf of A1 i.e. A11, A121, A122, A13 and A14
Thanks...
A
-A1
--A11
--A12
---A121
---A122
--A13
--A14
-A2
B
C
Thanks...
A
-A1
--A11
--A12
---A121
---A122
--A13
--A14
-A2
B
C
Re: Rule for Leaf of an item
At least three ways occur to me:
a put n: on the right hand side of the rule eg
['Value'] = n: ['Cost'] * ['Price'];
b Test the level of the element - 0 is the lowest
['X'] = if(ellev('Product',!Product) = 0, ['Y'],
#else
stet);
c Use ISLEAF
Using n: is the best approach, indeed I would assert that this should be on the vast majority of rule lines. Use <blank> for 'KPI' rules eg
['Gross Profit %'] = ['Gross Profit'] \ ['Revenue'];
and c: only rules are generally bad news as they interfere with the consolidation logic. (NB I said _generally_.)
Use ellev if you need to apply the rule to parents in other dimensions, but to base levels in this one.
I don't think I've worked out whether ISLEAF is useful, but it's there for completeness.
HTH
#else
stet);
c Use ISLEAF
HTH
- rkaif
- Version: 9.1 or later
You will have to use the ELLEV() function within your rule.
So your rule will look something like this:
[Area]=IF(ELLEV('Dimension',!Element)=0,'True', 'False');
You can also use N: in your rule. Depends upon what you are trying to achieve.
Cheers!
Rizwan Kaif
Rizwan Kaif
- Version: 9.5.1
Thanks for the input.
The formula has to apply to a specific item in the hierarchy, so it has to apply to Leafs of A1, but Not the leafs of A2 or B or C, Just leafs of A1.
- rkaif
Do you have access to the RTMF?
You can use ELISANC() function in your rule
[Area]=IF((ELLEV('Product',!Product)=0) & ELISANC('Product', 'A1', !Product)=1),'True', 'False');
Hope this helps!
Hope this helps!
Cheers!
Rizwan Kaif
Rizwan Kaif
- Version: 9.5.1
Thanks Kaif, it worked, but instead of ELLEV I just used N:, do you think its ok.
What is RTMF?
What is RTMF?
- rkaif
Yes that should be fine. You can use N: instead of using ELLEV() - but depends what you are trying to do. But I assume in your case it should be fine.
RTFM is referred to the Manual. Please dont ask me what RTFM stands for
Cheers!
Rizwan Kaif
Rizwan Kaif
- Version: 9.5.1
Kaif, which Manual is RTFM, I don't think I have it, can you please attach it with this thread?
- Martin Ryan
RTFM is an acronym that suggests that you will find what you are looking for in the manual. It is not name of the manual itself.
- Version: 9.5.1
Darn, a simple Google search told me what it is.. Read the ****** Manual...
- rkaif
Wow...that is so funny.tryinghard wrote:Kaif, which Manual is RTFM, I don't think I have it
Cheers!
Rizwan Kaif
Rizwan Kaif
