Strange Behaviour in TM1 Zero Suppression & Consolidation
Posted: Thu Aug 05, 2010 8:17 am
by mce
I started having a strange problem in a TM1 cube, for one item in a dimension.
For this item, it does not display anything when you suppress zeros, however when you disable zero suppression it displays values in leaf items.
Moreover, for this item, it does not display any number in consolidation elements of other dimensions although there are values in leaf elements and although there is no C level rule to overwrite the consolidation.
This looks quite strange to me. Have you seen this happening before? and what might be the cause? and how can I fix this problem?
Thanks in advance for replies.
Re: Strange Behaviour in TM1 Zero Suppression & Consolidatio
Posted: Thu Aug 05, 2010 10:23 am
mce wrote:Hi,
What you are describing sounds like a classic case of an unfed rule calculation. When zero suppression is off and you right click one of the cells that disappears what do you see when you select
- trace calculation?
- check feeders?
Posted: Fri Aug 06, 2010 3:02 pm
by mce
Yes, this seems to be the case. I changed the code for feeders and it seems to be ok now.
Thanks.
Posted: Fri Oct 12, 2012 10:53 am
by devathadeepak
I have the same issue can you please suggest wht you exactly did in feeders
Posted: Fri Oct 12, 2012 10:57 am
by qml
Mate, surely you don't expect his feeders to be the same as yours and his feeder problem to be the same as yours?
Post your rules with feeder statements and a description of your problem and you are guaranteed to get help. The more detail, the better.
