Has anyone had good or bad experiences to report on version 9.4?
Katie
TM1 9.4?
- Eric
- Version: 9.4
- Excel Version: 2003
Re: TM1 9.4?
http://forums.olapforums.com/viewtopic.php?f=3&t=208
Here is a post about 9.4. No one has implemented it in production to my knowledge. I think everyone is waiting for the first patch before even considering it.
Eric
Eric
- rodrigo
- OLAP Product: TM1, Executive Viewer
- Version: 9.4 MR1 with FP3
Re: TM1 9.4?
I believe that the possibility of going to 9.4 and a no way back to previous versions, is a "No" right now for our projects, Why this new feature? We had troubles when 9.1 appeared, and now?
Also one of my excel bar graphic didnt work at first sight..
Re: TM1 9.4?
Do you mean "why is there no going back"?rodrigo wrote:I believe that the possibility of going to 9.4 and a no way back to previous versions, is a "No" right now for our projects, Why this new feature? We had troubles when 9.1 appeared, and now?
I believe that it's because they changed the underlying data storage to Unicode, presumably to allow TM1 to expand into Asian markets in particular where a more expansive character set is needed.
Once you convert, though, there's no going back.
This is another reason why I suspect that most initial installations of 9.4 will be people who have never used TM1 before and don't know of the, er, "excitement" that can be expected from a Service Pack 0 release. I'd happily whack it on a test server if I had one to spare, but it'll be a spell before it hits production.
- jim wood
- Version: PA 2.0.7
Re: TM1 9.4?
I might dig an old box out of the attic to test 9.4 but we will not be upgrading any time soon from 9.1. I don't think it has anything within it that is driving us towards it,
Jim.
Jim.
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Re: TM1 9.4?
Started using it for demos. very limited testing so far.
Big irritation is if you are logged on to a 9.4 TM1 server and open a multi sheet workbook, each sheet will be opened in turn, weird and can make you feal queasy if done after lunch!
- Version: 9.4
Re: TM1 9.4?
I just had the same issue when I opened a multisheet workbook on the server. I noticed autocalc was on when I opened it. I killed the workbook without saving changes (so I didn't save it with autocalc on). Then, I turned off autocalc, reopened the workbook and pressed F9. It calculated without cycling through the sheets. For a test, I closed the workbook, turned on autocalc and reopened it. With autocalc turned on, the workbook calculated and then started cycling through the sheets again.
Do you know if Cognos aware of this? I have another ticket into them that is supposed to be resolved in a January release (see Bugs). Maybe they'll fix this by then too.
Kerry Pollock
IBM Certified Devoloper - Cognos TM1
- stephen waters
- Version: 10_2_2
Re: TM1 9.4?
Kerry
This was reported and, I think, has been passed to engineering as a bug
