hi,
please can anyone help me out in this, i have created a dimension named product through turbointegrator in advanced tab of 'prolog',the dimension product has created.
When i tried ti insert elements in the same dimension in the prolog tab itself.I got an error "DIMENSION CREATE PRODUCT FAILED". Please help me in this for create the dimension completely through turbointegrator.
Please give me the cause for this error.
thanking you.
Dimension Create
Re: Dimension Create
It's best to post your Prolog code. That'll make it easier than guessing.viswaraju wrote:hi,
viswaraju
- OLAP Product: IBM COGNOS TM1
- Version: 9.5
error :prolog procedure:dimension creation fails for dimension"customer"
TM1ProcessError_20100725103357_customer.log
boss this are the error details
No, I meant the code from your Prolog tab. It would be useful to see what the actual TI code is trying to do when it errors.viswaraju wrote:error :prolog procedure:dimension creation fails for dimension"customer"
viswaraju
- Version: 9.5
Boss i got it.
thank you
thank you
