Where is the Sample Data
- George Regateiro
- Version: 10.1.1
- Excel Version: 2007 SP3
I have been given some help that I now have to get up to speed on TM1. I wanted him to go through the rules guide but I cannot find the sample data that the guide uses. When I navigate to the directory C:\Program Files\Cognos\TM1\Custom\TM1Data\ all I see is the PData. I do not see the Rules_Guide_Data directory that should be installed. I have rerun the installation programs on the client but I did not see an option for this sample data. Where can63396705I find this in the installations? Unless I missed something in the guides I do not see it.
Re: Where is the Sample Data
{Deleted; see later posts}
- rkaif
- Version: 9.1 or later
I have got that Sample Data at this location:
C:\Program Files\Cognos\TM1\Custom\TM1Data\Rules_Guide_Data
As far I remember while installing the TM1 on this particular machine I selected the option of TM1Web. I am on version 9.4
Cheers!
Rizwan Kaif
Rizwan Kaif
You're right, it looks like it does install when you do a full TM1 install (based on what I'm seeing on my 9.5 test platform; I don't have a 9.4 one at the moment) though it doesn't register as a service. George's problem would therefore be that he did the Perspectives install instead. Doing a full install should get it.rkaif wrote:I have got that Sample Data at this location:
- George Regateiro
- Version: 10.1.1
Thanks for the help. It seems strange to have to do the full install, but that worked.
