Need Suggestion on the best approach for my task
Posted: Thu Jul 15, 2010 4:43 pm
I have the following task, and i need your suggestion on the best approach:
1) I need to create a template where the users will be able to enter data (or modify) and save to the cube.The users will be accessing the template through TM1 web. (9.5v)
I have a cube named cube1 with 8 dimensions. One of the dimensions, say Product --> The elements of product are Prod1, prod2, prod3, prod4, prod5, prod6,....
And i have five user groups,.. user1, user2, user3, user4, user5
Each user group will have access (able to modify the data,..see #2 below) to a particular product (user1 will have access to prod1, user2 will have access to prod2,...user3 will have access to prod3 and prod4,....).
2) Also, i need all the users to get a notification when any data is changed in the cube. (need to notify - who changed, when the change was done, what is the change, and the previous value)
What would be the best approach to achieve this?
Thank you.
Thank you.
