PDFCamp watermark
Kaveenga
OLAP Product: TM1 Palo
Version: TM1 9.x Palo 3.2
Excel Version: 2003 2007 2010
PDFCamp watermark
Post by Kaveenga »
Would appreciate your advice on how to remove the message "please purchase PDFcamp printer on http://www.verypdf.com/ to remove this watermark".
Thanks in advance
Kavee
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: PDFCamp watermark
Post by rkaif »
Kaveenga,
First of all your should not be getting any Watermarks by PDFCamp. The version of PDFCamp which you get with TM1 is registered and should not place and kind of watermarks on your PDF files.
Which version of PDFCamp you are using? As far as I know you will only get this water mark if you have installed the unregistered version of PDFCamp PRO
Attached is a sample PDF file created using PDFCamp on my personal computer.
Test Page.pdf
Test Page PDF Camp
(20.79 KiB) Downloaded 526 times
Cheers!
Rizwan Kaif
Kaveenga
Post by Kaveenga »
Hi Rizwan,
Thank you for your reply. We have PDFCamp Pro installed on our PCs, and the only way that got installed was because of TM1.
We are in the process of upgrading to TM1 9.5 and would like to rectify this. Would appreciate your thoughts.
Kind regards
Kavee
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Post by Martin Erlmoser »
i encountered a while ago some problems with the 9.4 installer - on some computers the license has not been installed.
but on some it worked, so i exported the license key out of the registry and imported it on the pc w/o license.. worked
maybe try this if you have a pc with working license or ask the ibm support for the appropriate reg key
(or just try to reinstall tm1..)
rkaif
Post by rkaif »
Are you in 32bit or 64 bit environment?
Sometimes in 64-bit environment you have to install the 64-bit version of PDFCamp. Have you checked the PDFCamp folder if it is missing any files? See the attached screens for the list of files you should have.
Also please check the PDFCamp printer properties (as shown in the attachments). It should say that it is the registered copy.
Else try reinstalling TM1.
PDFcamp printer properties
PDFcamp driver folder
PDFcamp folder
PDFcamp folder
Cheers!
Rizwan Kaif
Kaveenga
Post by Kaveenga »
Hi Rizwan,
Many thanks for your email. The reg key was found in the RegNo.reg file. However, I have emailed IBM asking for confirmation that entering the reg key found in this file will not breach any licence agreements.
Thanks again for your assistance.
Kind regards
Kavee
