I want implement Ctr+H functionality through TI process on worksheets.
How it helps:
If we want to move reports from one environment to other , we have to change server name from all subnm functions.
it takes hell out of time to do indivually if ur report is huge with many active form.
I tried to put cell reference(server Name) in all Subnm functions,so that i need to changes at only one place when u move reports across d environments,but Subnm never takes cell value in the place of server name.
Thats the reason i am trying for above alternative solution.
If you have any way ,kindly share.
Thanks in advance.
Nata
Ctr+H functionality through TI process on work sheets
nataraja.pl@tcs.com
- Version: 9.4
- Martin Ryan
Re: Ctr+H functionality through TI process on work sheets
Subnm will take a reference to a cell (e.g. =subnm(a1 & ":Scenario", "", "Actual")), however doing so will prevent the user being able to double click the subnm to change the element within TM1.
What I tend to do is to reference a cell for all of the TM1 formulae except subnms, which means I only have to change at most a dozen references, rather than potentially thousands.
Which version of 9.4 are you on? If it's 9.4.1 FP1 or higher, you should now be able to do that. See this thread.nataraja.pl@tcs.com wrote: I tried to put cell reference(server Name) in all Subnm functions,so that i need to changes at only one place when u move reports across d environments,but Subnm never takes cell value in the place of server name.
nataraja.pl@tcs.com
- Version: 9.4
Hi Alan/Martin,
Thanks a lot,i am using 9.4.1 version.
my syntax was incorrect ,thats y i was not able to do that.
I recorrected as martin mentioned,issue got resolved.
Thanks a lot martin & Alan.
Nata
Nata
