TM1 9.4 FP3 - I_PROCESS Problem
Luiz Gustavo
Version: 9.0 and 9.4.1
Excel Version: 97
Post by Luiz Gustavo »
Dear,
I am having some problems to execute the function "I_PROCESS" in VB with TM1 9.4 FP 3.
I have tried the SAME process with 9.0 and it works fine.
The scneario, if I create one test.cma and run the "Process Data" via the excel tm1 menu, I CAN upload the cma data into one cube, but if I do the same process using the macro:
Run "I_Process", "DIRECTORY\test"
or
Run "I_Process", "DIRECTORY\test.cma"
it doesn't work.
Note: The TM1 VB "W_CALC" works fine.
Luiz Gustavo
Excel Version: 97
Re: TM1 9.4 FP3 - I_PROCESS Problem
This error only occurs with Excel 2003 SP3, with SP2 it works fine...
any idea?
Luiz Gustavo
Excel Version: 97
This was fixed by HotFix 7
