Hi all
I was contemplating creating custom logging of TI process activity - to capture parameters etc
I could hard-code the path to the logging folder - but thought it would be better to pick up the logging path from the system - as declared in tm1s.cfg
Any ideas? I didn't see anything in TI variables
IanB
Access to logging folder via TI
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Access to logging folder via TI
There is a TI function available for this:
MichelGetProcessErrorFileDirectory
This is a TM1 TurboIntegrator function, valid only in TurboIntegrator processes.
This function returns the full pathname, with trailing slash, of the directory where TurboIntegrator process error files are written. (By default, all process error log files are written to the data directory of the server on which the process resides.)
Syntax
GetProcessErrorFileDirectory;
Arguments
None.
