Name of Processes in Turbo
borisslu
Post by borisslu »
HI,
can i now name of Processes that run in Turbo?
which function i must use?
Boris
Re: Name of Processes in Turbo
borisslu wrote: can i now name of Processes that run in Turbo?
There are no native functions which will allow you to change the names of TI processes. You name them when you save them using the GUI in Server Explorer. You can also Save As a different name. Aside from that the only way of doing it without resorting to third party tools is to use code written using the TM1 API, which I wouldn't recommend.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
There is a Turbo Integrator function that returns the name of the running process, if that's what you're after:
GetProcessName
This is a TM1 TurboIntegrator function, valid only in TurboIntegrator processes.
This function returns as a string the name of the current process.
Syntax
GetProcessName()
Arguments
None.
Example
Name = GetProcessName();
Michel Zijlema wrote:There is a Turbo Integrator function that returns the name of the running process, if that's what you're after:
Ooooh, he meant how can I know the name of the process... that does put it in a somewhat different context.
Michel Zijlema
borisslu wrote:Hi Michel,
i have a mistake that variable GetProcessName is undefined
that i must write?
Boris
Hi Boris,
Did you use the syntax as described in the example:
i.e. did you assign the result of the function to a variable and did you add the parenthesis at the end of the function?
What TM1 version are you using?
Michel
borisslu
Post by borisslu »
hi, Michel
i did this
but maybe this because version 9.1?
i undestand that this function exist onli in version 9.5?
thanks
Boris
borisslu wrote: i undestand that this function exist onli in version 9.5?
It appears so. There doesn't seem to be any reference to it in the release notes (what a surprise :roll: ), but doing a search through my document library shows it only in the 9.5 Reference .pdfs, not in those of any earlier version.
You could always assign the process name to a variable manually as a workaround.
Erm, cough, splutter, yes ...
Must say I was a bit surprised when I saw Michel's response. After I finished wiping coffee spray from the screen I did the same thing. That function would have saved me a lot of bother with hardcoding of process names over the years!
I must say about bloody time. Now if only IBM would pull their finger out and come up with a TI function for "TM1ServerVersion" so that it is possible to handle possible errors and branch code for use on different server versions. This would have been quite handy over the years for this case in point and also for the introduction of ViewExists, SubsetExists, etc. I'll just get my coat shall I ?...
Michel Zijlema
When I asked what version you're using? I thought Boris maybe is on some old (v8) version - I wasn't aware that this function was added this recently though...
I just tested: this function is also available in TM1 9.4.1FP3, but indeed not in 9.1.4 en before.
Michel
Michel Zijlema wrote:When I asked what version you're using? I thought Boris maybe is on some old (v8) version - I wasn't aware that this function was added this recently though...
Definitely wasn't documented in 9.4 though (unless it was in a later update to the docs which I don't have, though it's also not in the 9.4 MR1 Information Centre); the list of reserved words in the 9.4 TI manual, for example, include only two starting with Get:
GetProcessErrorFileDirectory, and
GetProcessErrorFilename.
Oh wait, I see why... I just re-checked my job description.
My job description wrote:Required to demonstrate abnormally high paranormal extra sensory perception abilities to detect when undocumented changes have been made to TM1 functionality.
Guess I'm gonna get marked down on that one in this year's appraisal.
IanB
OLAP Product: TM1 SSAS
Version: 9.5,10.2
Excel Version: 2010 2013 2016
Post by IanB »
Suppose that also applies to a function TIUserName - doesn't exist yet...
IanB wrote:Suppose that also applies to a function TIUserName - doesn't exist yet...
If you're referring to the TI function, the function name is actually TM1User, not TM1UserName. As per the release notes it was available by at least 9.1 SP3.
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent »
...and having just checked 9.0, 9.1 seems to be the 1st time it appeared too.
paulsimon
Version: PA 2.0.5
Post by paulsimon »
I've adopted the habit of creating a
vThisPro = '<process name>' ;
in the Prolog
as it then makes it easier when you want to save the process as a different name, or when I want to take the process name and paste it in to another process or a cube.
So, I think that there is still a reason for having a variable with the process name in a process.
