Executing VB Script via Scheduled TI process
anoops81
Version: 9.5.2
Excel Version: Office 2010
Post by anoops81 »
Hi All ,
We face Issues in EV while giving restricted/limited access to users. We use element level security in our department dimension . EV fails to get the full outline of the dimension structure and the restricted user will get "Invalid Outline defenition Error" while opening reports . The workaround to reslove this error is to run VB scripts manually to do a forced preload for the particular database connection . We have been doing this manually .
I was trying to Schedule the VB Script run via TI process . So I wrote the following commands in the epilog part of a new TI process
ExecuteCommand('D:\bat\ActualsPnL.bat',0);
ExecuteCommand('D:\bat\Attrition.bat',0);
ExecuteCommand('D:\bat\GL_ActualsVsBudgets.bat',0);
ExecuteCommand('D:\bat\ResourceCategories.bat',0);
ExecuteCommand('D:\bat\ResourceP&L.bat',0);
I am also attaching the VB Scripts and .bat files for your reference.
But when I run the process , I can see many cmd.exe process generated (In task Manager ) and nothing happened , I had to kill those cmd.exe's.
Could you please correct me on where I went wrong ?
Thanks & Regards
Anoop
Forced Preload.zip
VB Scripts & .bat files
(3.79 KiB) Downloaded 629 times
Re: Executing VB Script via Scheduled TI process
You can't just call the vbs. You need to call script.exe and pass the vbs as a parameter.
Look in this thread for the syntax.
anoops81
Version: 9.5.2
Post by anoops81 »
Thanks Lotsaram ,
I think it is working fine . I am not seeing the cmd.exe in windows task manager now. Is there any way to check whether the VB Script executed successfully for each run of the process ? When I am running the chore manually , I am getting "Process Executed Successfully" message .
Anoop
anoops81
Version: 9.5.2
Post by anoops81 »
Hi All ,
I am using the following execute commands in the epilog of a TI process ,
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_ResourceCategories.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_Actuals_AccountP&L.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_Actuals_Resource_Level.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_Aop_Actuals vs Budgets.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_Attrition.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_Attrition_old.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForecedPreload_HeadCount.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForcedPreload_GL_ActualsVsBudgets.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForcedPreload_Invoice_Aging_Report.vbs',0);
ExecuteCommand('C:\windows\system32\Cscript.exe C:\Forced Preload VB Scripts\ForcedPreload_PipeLine_Loss_Report.vbs',0);
Each of the VBScripts are supposed to do forced preload. But it is not happenning because i am getting the Invalid Outline Error. The Scripts are running fine when I am clicking them manually.
Could anyone please tell me what could be the reason ?
Anoop
Check the permissions of the user account that the TM1 service is running under. Is it able to run scripts or is scripting disabled?
anoops81
Version: 9.5.2
Post by anoops81 »
Hi Lotsaram ,
I logged in as that particular user (Service Account for TM1) , i was able to run the scripts manually . The account is having admin privileges in the server .
Thanks & Regards
Anoop
