Block user access to TM1 Contributor
Posted: Thu Jun 03, 2010 4:00 am
I'm implementing TM1 9.5 with TM1 Contributor. I used single sign-on (integrated login) with Active Directory (AD) for my security setting.
So, if a user has logged in to his Windows, then he doesn't have to entry username or password when opening the TM1 Contributor.
This single sign-on is implemented by using IBM Cognos Connection as the mediator between TM1 and AD.
Furthermore, the access right for each node in Contributor is assigned to a certain AD groups. So, for a user to has access to Contributor, I only have to assign him to a certain AD group.
My question is: Is it possible to block a group from accessing the Contributor during a certain period of time?
Thanks in advance for your help and answer guys n gals.
Comma
Comma
