I would like to implement CAM-Security for TM1, Cognos is using LDAP. I imported some users and groups to TM1 but when I want to delete a client it does not work. The user disappears from the security in TM1, but when I log in with the credentials I just deleted it works and the credentials appear again in the security cube.
- What do I have to do if I want to delete a client that was imported from CAM/LDAP?
Thanks a lot,
Toto
Using CAM-Security
Re: Using CAM-Security
What you are describing is just how CAM security works. After you have set up the TM1 server to work with CAM when a user logs on via CAM if that user does not already exist as a TM1 client then the user is created.Toto wrote:What do I have to do if I want to delete a client that was imported from CAM/LDAP
To remove a user from }Clients either don't log back on as that user after removing the user within TM1 and/or remove that user from within CAM administration.
