Prolog:
NumericSessionVariable('a');
NumericSessionVariable('b');
NumericSessionVariable('c');
StringSessionVariable('d');
Epilog:
b=ELCOMPN('dim','Consolidation');
Metadata:
While(b<1);
d=ELCOMP('dim,'Consloidation,b);
a=if(dayno(today)-Dayno
(ATTRS('dim',d,'StartDate'))>366,
1,0);
If(a=0);
DimensionElementcomponentDelete('dim','Consolidation',d);
DimensionElementcomponentAdd('dim,'Consolidation',d,+1);
EndIf;
b=b-1;
End;
actually i have to get the element in a consolidation as string variable in 'd'. but i am not getting it. Pls correct me whereever I am wrong.
Monisha
Can't assign variable
- Martin Ryan
Re: Can't assign variable
Hi Monisha,
First up, please start new topics by creating a new topic, rather than tacking them onto other topics at random. This makes things very confusing for both the original topic and the new topic.
Your problem is that you are inconsistently using the single quote. If you start something with a single quote, you must close it
should be
d=ELCOMP('dim,'Consloidation,b);Code: Select all
d=ELCOMP('dim','Consloidation',b);Please do not send technical questions via private message or email. Post them in the forum where you'll probably get a faster reply, and everyone can benefit from the answers.
VRGultom
- OLAP Product: SqlServer 2005
- Version: SqlServer 2005
- Excel Version: 2005
http://publib.boulder.ibm.com/infocente ... 30AF9.html
The ELCOMP function returns a child of a consolidated element. This function accepts three arguments: a dimension name, an element name, and an index number for the child.
ELCOMPN returns the number of components in a specified element. If the element argument is not a consolidated element, the function returns 0.
Syntax :ELCOMPN(dimension, element)
While(b<1);
1,0);
If(a=0);
EndIf;
b=b-1;
End;
from your code, b must be always 0 because your code : while (b<1). So the loop will be process only if b<1 which is 0
so from this code : b=ELCOMPN('dim','Consolidation');
you have to make sure that your element is not consolidated element to have b =0 to process the loop
VRG
While(b<1);
1,0);
If(a=0);
EndIf;
b=b-1;
End;
VRG
