AD security in TM1 for multiple user in 1 PC
appleglaze28
- Excel Version: 2003
I want to know how to set up using the AD security in TM1...I've read some thread that use Integrated Security but with this, once a user has logged on to his or her unit, I assume her users in TM1 would also be already authenticated. What if someone's PC in a department breaks down and would require to log in to TM1 to make changes. Rather than having to a user log out of his PC so another can use would be time consuming especially if the changes he needs to do in TM1 is so minimal.
olapuser
- Version: 9.5
Re: AD security in TM1 for multiple user in 1 PC
i think you can use run as from command line, i do not know exactly the command, please ask mr google
you need not set up anything in TM1, it is from windows side.
