I do not understand the concept of adding a EV Server. When I add another server I have the exact views, databases and data sources in it than in the first EVServer. In my first demoserver I have the following settings:
cabLocation>http://myhost/EVServer/Client
Should I have the same entries in my second server?
Why should I have more than one server?
Thanks a lot for your help!!
Toto
Executive Viewe - Add a server
- rkaif
- Version: 9.1 or later
Re: Executive Viewe - Add a server
You will only add a server if you want to connect to another TM1 Server
You also have do some settings in the EVServer.exe.config file
Cheers!
Rizwan Kaif
Rizwan Kaif
