Newbie Mystery Question #9:
I have a spreadsheet with approx. 12,000 values I am trying to load into cube. I have written both a DBS and DBRW formula which I am trying to copy into. If I copy one cell at a time, the Excel copy function works. If I do a block of cells, it does not. Any clues? In meantime just doing straight DBS link with the appropriate cell value. Thanks.
9.1 Cut-n-Paste into a DBS or DBRW formula
Re: 9.1 Cut-n-Paste into a DBS or DBRW formula
You've never been able to copy a block of cells and paste them directly into DBRW formulas. However as you've discovered, doing it with a single cell will work. This is an undocumented "feature" which I've bagged out previously because I don't like inconsistency when it comes to user interface functionality, and I like it even less when it's not docuemnted. Why the copy and paste functionality wasn't implemented as part of the standard TM1 functionality long ago I have no idea.rfielden wrote:Newbie Mystery Question #9:
In the meantime you can download TM1 Tools (http://forums.olapforums.com/viewtopic.php?f=21&t=2515) which has it built in. Be aware that there are still a few bugs in the copy/paste functionality which I know about (hey, I wrote it in only a few hours...
- Version: 9.5.2
Thank you sir. You and a few others should be getting a portion of our annual maintenance fee to IBM, if not all of it!
