After installing TM1 Workflow-i am not seeing the workflow button in excell spreadsheet- please advise.
regards,
ravi
Not able to install Tm1 Workflow
- Excel Version: 2003
Re: Not able to install Tm1 Workflow
Open Excel and then under Tools click Add-ins and then Browse. Browse to the folder where TM1 is installed which by default is under Program Files and then under Cognos then TM1, click bin. Under "bin" you will find 4 .xla files click on TM1 Planning Manager. Then just click okay to return to excel, the TM1 Workflow will generally load automatically.
- Version: 9.5.1
I have the same problem. And, I tried the way that appleglaze28 mentioned. But, I still can't see the workflow toolbar in excel. What's wrong?
The version of excel is 2003 and TM1 is 9.5.1.
