Capacity of title box of dimension
busdee
Version: 9.5
Post by busdee »
I got warning msg when opened dimension subset editor as follow
"The capacity of titlt box is 4,000 items. You have picked an element with an index greater than 4,000, which cannot be displayed.
However, the value will be calculated correctly."
What should I do? I want to pick element with index greater than 4,000
Re: Capacity of title box of dimension
Just select a subset with <4000 elements before selecting the member.
LutherPaul
Post by LutherPaul »
I too ran into the same situation today. Is there a setting to increase the 4000 limit?
This is not a show stopper.
Thanks in advance.
Paul.
