in my cube view the options to create slices, shapshots and forms are deactivated. Where can I activate these options?
My second question is: In an example active form, if I type in a cell =language the result is English e.g. Where does the variable take this value from? Where can I define those variables?
Thanks a lot for you help!
Toto
Activate slice creation
Re: Activate slice creation
Which client? Perspectives (Excel add-in) or Architect (stand alone). You need to be using Perspectives to be able to interact with TM1 via Excel.Toto wrote:in my cube view the options to create slices, shapshots and forms are deactivated. Where can I activate these options?
Toto
- Version: 9.5 Build 9.5.00100.2380
- Excel Version: 2003
Ah, I used Architect.. Thanks for your help!
Toto
Toto
