Transfer Data from 1 element to another and erasing data
Posted: Wed Apr 21, 2010 9:49 am
by appleglaze28
I was wondering, what's the best way to transfer data 1 element to another with the same cube and zero out that original element's data without deleting the element in the dimension.
I do have to define a cube view of the cube and just edit the dimension that's gonna be doing the transfering, right? IF so im getting an invalid expression with the code below. I have 3 more cubes that needs to do these. This is my first time to use the VALUE_IS_STRING...so I'm not too familiar yet on how it works.
if (VALUE_IS_STRING=1, CellGetS(SVALUE,'general_so_setting',base_worksheet_account_manager,base_worksheet_so_number,value_so_setting), CellGetN(NVALUE
, 'general_so_setting', base_worksheet_account_manager,base_worksheet_so_number,value_so_setting));
if (VALUE_IS_STRING=1, CellPutS(SVALUE,'general_so_setting',base_worksheet_account_manager,base_worksheet_so_number,value_so_setting), CellPutN(NVALUE
Re: Transfer Data from 1 element to another and erasing data
Posted: Wed Apr 21, 2010 10:25 am
by kpk
You use incorrect syntax in your Cellget functions.
CellGetN(NVALUE,'general_so_setting'
The first argument in these functions has to be the name of the cube.
CellGetS('general_so_setting'
CellGetN('general_so_setting'
BTW:
You can see a useful sample code for coping data at the following link: http://www.wimgielis.be/
Check the "Copy all data from one element to another" article.
Peter
Posted: Thu Apr 22, 2010 3:03 am
by appleglaze28
How do I erase the element from the original source? Cause I'm not sure how that's done, I'm just familiar with zeroing out the whole view.
Posted: Thu Apr 22, 2010 3:09 am
by Alan Kirk
appleglaze28 wrote:How do I erase the element from the original source? Cause I'm not sure how that's done, I'm just familiar with zeroing out the whole view.
Your original post said that you didn't want to delete the element.
appleglaze28 wrote:and zero out that original element's data without deleting the element in the dimension.
Have you looked at the TM1 Reference Guide from the Help menu? It contains all of the TI commands, grouped by function. The relevant one in this case is DimensionElementDelete.
If you actually meant "erase the data relating to that element", you simply build a view with that one element (or as many as you want to erase) as one of the subsets which define the view (plus whatever other subsets are needed), and zero out that view.
Posted: Thu Apr 22, 2010 3:52 am
by appleglaze28
Thanks for correcting me Alan, yeah I meant erasing the data from the orignal element.
Posted: Thu Apr 22, 2010 3:55 am
by Alan Kirk
appleglaze28 wrote:Thanks for correcting me Alan, yeah I meant erasing the data from the orignal element.
OK, well, that's the way you do it then; whether it's 1 element or 10,000, you just create a view and zero that view out.
Posted: Thu Apr 22, 2010 3:59 am
Or if it's actually a specific cell as it looks like it might be from the original post then simply CellPutN a 0 or CellPutS a space character.
Posted: Thu Apr 22, 2010 7:35 am
by appleglaze28
Thanks guys for the help...I was wondering if i would do this for 1 elements for 2 dimension, I would just probably need to copy the TI for the single element and adjust it base on the new dimension and its related element, right? So I did that....but the process runs okay but its like nothing happens to the cube. I was like thinkng of creating multiple TI to transfer them from 1 dimension to another but I would end up with 8 TI for just this task. Since I have 4 cubes I already have 4 TI for the transfer of 1 element in 1 dimension.
Maybe someone can help me look at the process and see why its running fine but nothing happens for the output...cause for example i inputted data for an element for a specific date, and it ends up being on the wrong element for the wrong date, that would be the purpose of transfering the data to elements in 2 dimensions.
Thanks Wim for the help on this.
PRAMETER:
pSourceElement
pTargetElement
pSourceElementDate
pTargetElementDate
PROLOG:
## A. Explicit constants
vCubeName='worksheet';
vSourceViewName='Source';
vTargetViewName='Target';
vSourceSubsetName='Target';
vTargetSubsetName='Source';
pDimensionName='base_worksheet_so_number';
pDimensionDate='base_worksheet_date';
## B. Preliminary checks
#dimension-related
IF(DIMENSIONEXISTS(pDimensionName)=0);
     PROCESSQUIT;
ENDIF;
IF(DIMENSIONEXISTS(pDimensionDate)=0);
     ITEMSKIP;
ENDIF;
# elements-related
IF(DIMIX(pDimensionName,pSourceElement)=0);
     PROCESSQUIT;
ENDIF;
IF(DIMIX(pDimensionDate,pSourceElementDate)=0);
     PROCESSQUIT;
ENDIF;
IF(DIMIX(pDimensionName,pTargetElement)=0 %
   DTYPE(pDimensionName,pTargetElement)@='C');
     PROCESSQUIT;
ENDIF;
IF(DIMIX(pDimensionDate,pTargetElementDate)=0 %
   DTYPE(pDimensionDate,pTargetElementDate)@='C');
     PROCESSQUIT;
ENDIF;
IF(TRIM(pSourceElement)@=TRIM(pTargetElement));
     PROCESSQUIT;
ENDIF;
IF(TRIM(pSourceElementDate)@=TRIM(pTargetElementDate));
     PROCESSQUIT;
ENDIF;
# process-related
IF(DATASOURCETYPE@<>'VIEW');
     PROCESSQUIT;
ENDIF;
IF(DATASOURCENAMEFORSERVER@<>vCubeName);
     PROCESSQUIT;
ENDIF;
IF(DATASOURCECUBEVIEW@<>vSourceViewName);
     PROCESSQUIT;
ENDIF;
## C. Create a view containing all data for the Source element
# 1. Tidy up the Source view
VIEWDESTROY(vCubeName,vSourceViewName);
SUBSETDESTROY(pDimensionName,vSourceSubsetName);
SUBSETDESTROY(pDimensionDate,vSourceSubsetName);
# 2. Create subset
SUBSETCREATE(pDimensionName,vSourceSubsetName);
SUBSETELEMENTINSERT(pDimensionName,vSourceSubsetName,
                    pSourceElement,1);
SUBSETCREATE(pDimensionDate,vSourceSubsetName);
SUBSETELEMENTINSERT(pDimensionDate,vSourceSubsetName,
                    pSourceElementDate,1);
# 3. Create view & assign subset
VIEWCREATE(vCubeName,vSourceViewName);
VIEWSUBSETASSIGN(vCubeName,vSourceViewName,
IF(DTYPE(pDimensionName,pSourceElement)@='C');
     VIEWSETSKIPCALCS(vCubeName,vSourceViewName,0);
ENDIF;
IF(DTYPE(pDimensionDate,pSourceElementDate)@='C');
ENDIF;
VIEWSETSKIPRULEVALUES(vCubeName,vSourceViewName,0);
## D. Zero out a view containing all data for the Target element
# 1. Tidy up
VIEWDESTROY(vCubeName,vTargetViewName);
SUBSETDESTROY(pDimensionName,vTargetSubsetName);
SUBSETDESTROY(pDimensionDate,vTargetSubsetName);
# 2. Create subset
SUBSETCREATE(pDimensionName,vTargetSubsetName);
SUBSETELEMENTINSERT(pDimensionName,vTargetSubsetName,
                    pTargetElement,1);
SUBSETCREATE(pDimensionDate,vTargetSubsetName);
SUBSETELEMENTINSERT(pDimensionDate,vTargetSubsetName,
                    pTargetElementDate,1);
VIEWCREATE(vCubeName,vTargetViewName);
VIEWSUBSETASSIGN(vCubeName,vTargetViewName,
# 4. Zero out the view
VIEWZEROOUT(vCubeName,vTargetViewName);
# 5. Tidy up
DATA:
#dimension-related
     PROCESSQUIT;
ENDIF;
     ITEMSKIP;
ENDIF;
# elements-related
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
# process-related
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
     PROCESSQUIT;
ENDIF;
# 2. Create subset
                    pSourceElement,1);
ENDIF;
ENDIF;
# 1. Tidy up
# 2. Create subset
                    pTargetElement,1);
# 5. Tidy up
EPILOG:
# 4. Tidy up the Source view
