A client of ours (hi, Jarda) has been experiencing sporadic issues where the 'base' directory for a TI asciioutput command is changing from the tm1 server directory, writing instead to a user subdirectory (where private views and subsets are stored). It seems to come and go quite quickly.
Has anybody else experienced this?
Version is 9.0SP3 U9.
Base directory for TI moving
Re: Base directory for TI moving
Yes, I know I've seen it in 8.2.12. I can't recall exactly how it comes about (I've tried a few things on 9.0 tonight but haven't been able to reproduce it) but I know I've seen instances where the current directory from TM1's point of view is pointing to a user folder. I've never worried too much about tracing it down because we always use full paths for Asciioutputs anyway (which is never the data directory, since I don't want that cluttered up with muck), and have ExecuteCommand batch files called from a folder which has been added to the Path environment variable.David Usherwood wrote:A client of ours (hi, Jarda) has been experiencing sporadic issues where the 'base' directory for a TI asciioutput command is changing from the tm1 server directory, writing instead to a user subdirectory (where private views and subsets are stored). It seems to come and go quite quickly.
