Hello everybody,
I've got an issue with websheets.
In a report done with Excels I've put a wrap formatting to fix the width of a column.
Using this Excel sheet in Tm1web doesn't work properly because the cell changes its width in function of its text.
Is it a normal behaviour so wrap cell function cannot be used in tm1 websheets?
if no is there a solution for this problem?
thanks in advance,
Nicola
