Has anyone tried testing out BI Security extensively...? Cause I tried integrating it but just lately users are having errors related to Cognos BI "CAMPassport Error". Regardless how you change the tm1p.ini file it won't work. Previously we had to delete the user's Windows' user profile and recreate it to make it work. Now even that doesn't work. What other things do I need to check? Cause there was an instance as well when the users couldn't log in. the CognosURIGateway which I already preset like months ago, now there's nothing written in the CognosURIGateway in the TM1p.ini file.
What do you think is the pros & cons with using BI Security against TM security?
TM1 BI Security Integration Issue?
appleglaze28
- Excel Version: 2003
