Hi Everyone ,
We are having around 300 cognos tm1 users globally . Currently users are accessing the tm1web link via VPN client (VPN profile). We would like to publish the tm1 web link and EV link in internet so that all users can see the reports with out logging to VPN client .
Please suggest me how should I go forward on this ? Is there any configuration settings which has to be changed from tm1 side ?
Waiting for your valuable inputs .
Thanks & Regards
Anoop
Publishing Tm1web link in internet (http to https)
- rkaif
- Version: 9.1 or later
Re: Publishing Tm1web link in internet (http to https)
As long as your TM1Web is running on your Intranet, your users will have to VPN to connect to your network in order to access the TM1 server. You have 2 choices:
1. Publish PDF (static) reports on Internet so that users can access these reports using Internet & they will not have to connect to VPN
2. Otherwise you have to move your TM1Web server from Intranet to Internet...so that you can access your TM1 server without VPN.
Cheers!
Rizwan Kaif
Rizwan Kaif
