ti to load data from spreadsheets
Posted: Mon Apr 05, 2010 10:31 pm
by scrummyd
can someone please give an example on how to use ti to have a spreadsheet as a datasource which will be password protected to open and sheet protected. I've only ever used csv files.
And is it possible to load data from different sheets?
Re: ti to load data from spreadsheets
Posted: Tue Apr 06, 2010 12:46 am
by Martin Ryan
It's not possible to use spreadsheets as a source to TI. The best you can do is save the file as csv then load from there. Or use DBS formulae.
Martin
Posted: Tue Apr 06, 2010 4:32 pm
by David Usherwood
Yonks ago I tried using Excel as an ODBC source and it worked. This wasn't with TM1 though.
Posted: Tue Apr 06, 2010 6:33 pm
by Alan Kirk
David Usherwood wrote:Yonks ago I tried using Excel as an ODBC source and it worked. This wasn't with TM1 though.
I played around with that idea yesterday myself just out of curiosity; couldn't get it it to work with a TI. Named ranges, dollar signs after the sheet names, all the usual bumpf; none of the syntaxes flew because the TI "couldn't connect to the database". Also I did notice one MSDN article (didn't keep a reference to it as it seems to be academic now) which stated that it won't ever work with a passworded workbook, even if you supply the password which pretty much negated the OP's plans.
Posted: Thu Apr 08, 2010 4:18 pm
by Viet
Hi there,
Yes TI works well with ODBC on Excel files.
Don't forget to name the table range and provide a header row.
Viet
Posted: Thu Apr 08, 2010 10:06 pm
by Alan Kirk
Viet wrote: Yes TI works well with ODBC on Excel files.
Which version(s) have you done this on? Because that was exactly the configuration that I had when I tested it in 9.0 SP3 and it refused to read the data.
Also, have you tried it with a passworded workbook as per the original question, or only with unpassworded ones?
Posted: Fri Apr 09, 2010 6:56 am
by Wim Gielis
I tested it on TM1 9.4 MR1, and Excel 2007.
Passworded files cannot be used, it seems.
