picklist with aliases
nicola531
Version: 9.5.1
Post by nicola531 »
Hello everybody,
a question: is that possible using picklist with Aliases instead of members?
I want to show the description instead of the real member but I only found this sintax.
dimension:Dimension_name
thanks in advance for you help,
Nicola
asvlad
OLAP Product: TM1, Transformer, EP, MSAS
Version: 2.0.6
Re: picklist with aliases
Post by asvlad »
you can use "Subsets", which have been saved with useing aliases
Are you doing this in the Subset Editor or Excel?
If you are in the case of the former, follow the advice of asvlad. If you are in the case of the latter, use the SUBNM function.
