55: Object Not Found for TM1 Websheet
Posted: Mon Mar 29, 2010 1:58 am
by appleglaze28
I was wondering if anybody has encountered this problem...some of my websheet are working and i can open and work on them but there are some that encounter an error and a dialog box pops up and says "55 Object Not Found".
Re: 55: Object Not Found for TM1 Websheet
Posted: Tue Feb 05, 2013 2:26 am
by USA11SF
Did you solve this issue yourself? Solution?"
Posted: Wed Feb 06, 2013 5:57 am
by Andy Key
Try reloading the navigation tree and open the web sheet again.
It is possibly the case that you have deleted and then re-Uploaded a web sheet using an existing name. (Which seems to be a requirement these days as Updating websheets gives me a pile of garbage when I reopen them.) The issue is that the code behind the navigation tree is still looking at a link to the old file, which no longer exists. Reloading the tree refreshes the XML so that it now looks at the new file.
